Sanding Zipflex
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=56144
Author:  guitarmaker78 [ Sun Dec 24, 2023 3:39 am ]
Post subject:  Sanding Zipflex
I’m considering using some zip flex abalone, but I am unsure if it is sandable.
On my first guitar, I had to sand the abalone, and I am unsure if the zip flex can be sanded or not.
If not, what is the technique for installing? Set it below the surface of the wood and sand the wood down even?
Author:  martintaylor [ Sun Dec 24, 2023 4:23 am ]
Post subject:  Re: Sanding Zipflex
Zipfkex is real she’ll so can be sanded. There is the same health risk so make sure you have adequate protection.
Author:  SteveSmith [ Sun Dec 24, 2023 5:07 am ]
I try to install it as close to level with the wood surface as possible, just a few thousandths above, to minimize sanding but otherwise no issues. Image
Author:  guitarmaker78 [ Sun Dec 24, 2023 12:57 pm ]
Appreciate the feedback.
Author:  Kbore [ Sun Dec 24, 2023 5:20 pm ]
The chatoyant part of the zip flex I used was thin on some sections. You want to do minimal sanding.
Author:  jfmckenna [ Sun Dec 24, 2023 8:13 pm ]
I've only used it twice but never had a problem sanding it. As mentioned keep your tolerance tight but I do that with regular abalone too
Author:  dofthesea [ Wed Dec 27, 2023 6:34 pm ]
If possible I try and have the Zipflex a few thousands lower and fill with CA glue. Sanding the zipflex makes me nervous
Author:  guitarmaker78 [ Thu Dec 28, 2023 3:42 am ]
Sounds like a good strategy.
